Aller au contenu principal
Dell Inspiron 15 3565 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 3565 Display Assembly Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  2. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Display Hinges: étape 2, image 1 de 1
    • Open the display hinges to an angle of 90 degrees.
  3. Dell Inspiron 15 3565 Display Assembly Replacement, Peeling the Tape: étape 3, image 1 de 1
    • Peel the tape that secures the display cable to the palm-rest assembly.
  4. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Latch: étape 4, image 1 de 1
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Latch: étape 5, image 1 de 1
  6. Dell Inspiron 15 3565 Display Assembly Replacement, Note the Routing: étape 6, image 1 de 1
    • Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
  7. Dell Inspiron 15 3565 Display Assembly Replacement, Note the Antenna Cable: étape 7, image 1 de 1
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  8. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Palm-Rest Assembly: étape 8, image 1 de 1
    • Open the palm-rest assembly at an angle and slide it off the display assembly.
  9. Dell Inspiron 15 3565 Display Assembly Replacement, Placing the Display Assembly: étape 9, image 1 de 1
    • Place the NEW display assembly on a clean, flat surface.
  10. Dell Inspiron 15 3565 Display Assembly Replacement, Placing the Palm-Rest Assembly: étape 10, image 1 de 1
    • Place the palm-rest assembly on the display assembly.
  11. Dell Inspiron 15 3565 Display Assembly Replacement, Close the Hinges: étape 11, image 1 de 1
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  12. Dell Inspiron 15 3565 Display Assembly Replacement, Replace the Screws: étape 12, image 1 de 1
    • Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  13. Dell Inspiron 15 3565 Display Assembly Replacement, Routing the Antenna Cables: étape 13, image 1 de 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  14. Dell Inspiron 15 3565 Display Assembly Replacement, Connecting the Display Cable: étape 14, image 1 de 1
    • Connect the display cable and close the latch to secure the cable.
  15. Dell Inspiron 15 3565 Display Assembly Replacement, Route the Display Cable: étape 15, image 1 de 1
    • Route the display cable through the routing guides on the palm-rest assembly
  16. Dell Inspiron 15 3565 Display Assembly Replacement, Adhering the Tape: étape 16, image 1 de 1
    • Adhere the tape that secures the display cable to the palm-rest assembly.
    • Close the display and turn the computer over.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 819
