Aller au contenu principal
Dell Inspiron 15 3568 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 3568 Hard Drive Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Latch: étape 2, image 1 de 2 Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Latch: étape 2, image 2 de 2
    • Lift the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 15 3568 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 15 3568 Hard Drive Replacement, Disconnecting the Interposer: étape 4, image 1 de 1
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 15 3568 Hard Drive Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15 3568 Hard Drive Replacement, Placing the Hard-Drive Bracket: étape 6, image 1 de 1
    • Place the hard-drive bracket over the NEW hard drive and align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  7. Dell Inspiron 15 3568 Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 3568 Hard Drive Replacement, Sliding the Hard-Drive Assembly: étape 8, image 1 de 1
    • Slide the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 3568 Hard Drive Replacement, Slide the Hard-Drive Cable: étape 9, image 1 de 2 Dell Inspiron 15 3568 Hard Drive Replacement, Slide the Hard-Drive Cable: étape 9, image 2 de 2
    • Slide the hard-drive cable into its connector and close the latch to secure the cable.
  10. Dell Inspiron 15 3568 Hard Drive Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
Un commentaire
SSD slot is available or not ? thank you
mbu Shrestha - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 732
