Aller au contenu principal
Dell Inspiron 15 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 Display Assembly Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Remove the screws that secure the display hinges to the palm-rest assembly and open the hinges to an angle of 90 degrees.
  2. Dell Inspiron 15 Display Assembly Replacement, Note the Antenna Cable: étape 2, image 1 de 1
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  3. Dell Inspiron 15 Display Assembly Replacement, Noting the Display Cable: étape 3, image 1 de 1
    • Note the display cable routing and remove the cable from its routing guides on the palm-rest assembly.
  4. Dell Inspiron 15 Display Assembly Replacement, Open the Assembly: étape 4, image 1 de 1
    • Open the palm-rest assembly.
  5. Dell Inspiron 15 Display Assembly Replacement, Lifting the Palm-Rest Assembly: étape 5, image 1 de 2 Dell Inspiron 15 Display Assembly Replacement, Lifting the Palm-Rest Assembly: étape 5, image 2 de 2
    • Lift the palm-rest assembly at an angle off the display assembly.
  6. Dell Inspiron 15 Display Assembly Replacement, Placing the Display Assembly: étape 6, image 1 de 1
    • Place the display assembly on a clean, flat surface.
  7. Dell Inspiron 15 Display Assembly Replacement, Placing the Display Assembly: étape 7, image 1 de 1
    • Place the NEW display assembly on the palm-rest assembly.
  8. Dell Inspiron 15 Display Assembly Replacement, Close the Display Hinges: étape 8, image 1 de 1
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  9. Dell Inspiron 15 Display Assembly Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  10. Dell Inspiron 15 Display Assembly Replacement, Route the Display Cable: étape 10, image 1 de 1
    • Route the display cable through its routing guides on the palm-rest assembly.
  11. Dell Inspiron 15 Display Assembly Replacement, Routing the Antenna Cables: étape 11, image 1 de 1
    • Route the antenna cables through its routing guides on the palm-rest assembly.
    • Close the display and turn the computer over.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
Un commentaire
I can't replace the cables on the left side of the lid through the hinge.
Peter Meyer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 58
Total : 1,586
