Introduction
This replacement guide will explain how to insert a new memory card into the Dell Inspiron 15-3521 laptop. Keep in mind that to perform this replacement, you will be opening the interior of your device, so it is best to perform this replacement in a clean environment.
We are removing the battery to avoid the possibility of an electrical discharge when working with this system. Flip the laptop over. Slide the latches toward the outside of the laptop to unlock the battery.
  • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
  • Flip the laptop over.
  • Slide the latches toward the outside of the laptop to unlock the battery.
  • Lift the battery out of the laptop.
Ajouter un commentaire
Loosen the two screws attaching the access door to the laptop body Using a spudger, pry open the access door  from the laptop Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  • Loosen the two screws attaching the access door to the laptop body
  • Using a spudger, pry open the access door from the laptop
  • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
To access the memory cards, push out the latches on the left and right of the memory cards To remove the memory card, pull it out of the tray with the latches still stretched out Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
  • To access the memory cards, push out the latches on the left and right of the memory cards
  • To remove the memory card, pull it out of the tray with the latches still stretched out
  • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
6 autre(s) ont terminé cette réparation.
Andrew Dippre
Membre depuis le 13/10/2014
2 284 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 3-1, Benson Fall 2014 Membre de l'équipe Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 53
Total : 3,595
