Aller au contenu principal
Dell Inspiron 15-3531 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: étape 2, image 1 de 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: étape 2, image 2 de 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: étape 2, image 3 de 3
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel from the laptop using the spudger.
  3. Dell Inspiron 15-3531 Hard Drive Replacement: étape 3, image 1 de 2 Dell Inspiron 15-3531 Hard Drive Replacement: étape 3, image 2 de 2
    • Lift the access panel away from the laptop to reveal the hard drive on the left.
    • Remove the two 8.65 mm screws on the left side of the hard drive using the PH0 head screwdriver.
    • There is a plastic tab beneath the hard drive.
  4. Dell Inspiron 15-3531 Hard Drive Replacement: étape 4, image 1 de 3 Dell Inspiron 15-3531 Hard Drive Replacement: étape 4, image 2 de 3 Dell Inspiron 15-3531 Hard Drive Replacement: étape 4, image 3 de 3
    • Push the hard drive to the left to release it and use the tab to pull it free from the laptop. The hard drive is in a caddy.
    • Remove the two 1.22 mm screws holding the hard drive in the caddy with the PH0 head screwdriver.
Kody Dahlke
Membre depuis le 02/15/18
730 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G5, Leahy Spring 2018 Membre de l'équipe USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 995
