Introduction
Is the touchpad in your Dell Inspiron 15-3543 not working properly, sticking down, or is unresponsive?
If so, here is the guide to fix the problem by simply replacing your touchpad. You will need the #0 Phillips screwdriver and opening tools, in order to remove the 19 screws involved with this replacement and pry the top panel from the bottom panel.
Ce dont vous avez besoin
Flip the device over so the bottom is facing up.
Using a #0 Phillips screwdriver, remove the 4.0mm screw to the right of the disk drive.
