Pièces
Aucune pièce nécessaire.
Make sure the laptop is powered down before you remove the battery.
  • Make sure the laptop is powered down before you remove the battery.
Ajouter un commentaire
Locate the battery release switch on the bottom of the laptop.
  • Locate the battery release switch on the bottom of the laptop.
Slide the battery release switch away from the lock symbol towards the “unlock” position. A click sound will let you know it has unlocked.
  • Slide the battery release switch away from the lock symbol towards the “unlock” position. A click sound will let you know it has unlocked.
The battery will rotate outward by lifting the bottom lip that pops out, and rotating it towards the top of the laptop until the battery comes free from the laptop. The battery will rotate outward by lifting the bottom lip that pops out, and rotating it towards the top of the laptop until the battery comes free from the laptop.
  • The battery will rotate outward by lifting the bottom lip that pops out, and rotating it towards the top of the laptop until the battery comes free from the laptop.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Keyboard Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
  • Keyboard
  • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.* Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
  • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
Flip the keyboard over onto the palm-rest assembly.
  • Flip the keyboard over onto the palm-rest assembly.
Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer. Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
CD-Drive
  • CD-Drive
  • Flip the computer over, *screen down* and unscrew the 1 screw in the middle located below the battery with a J0 bit tipped screwdriver.
Next using the J0 bit tipped screwdriver unscrew the 2 remaining screws shown in the picture.
  • Next using the J0 bit tipped screwdriver unscrew the 2 remaining screws shown in the picture.
After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer. After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer.
  • After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer.
Chandler Champion
Membre depuis le 23/01/2018
364 Réputation
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 36
