Introduction
The following guide will give instructions on how to properly replace the harddrive on your Dell Inspiron 15-5552.
Pièces
Aucune pièce nécessaire.
Make sure the laptop is powered down before you remove the battery.
  • Make sure the laptop is powered down before you remove the battery.
Ajouter un commentaire
Locate the battery release switch on the bottom of the laptop.
  • Locate the battery release switch on the bottom of the laptop.
Slide the battery release switch away from the lock symbol towards the “unlock” position. A click sound will let you know it has unlocked.
  • Slide the battery release switch away from the lock symbol towards the “unlock” position. A click sound will let you know it has unlocked.
The battery will rotate outward by lifting the bottom lip that pops out, and rotating it towards the top of the laptop until the battery comes free from the laptop. The battery will rotate outward by lifting the bottom lip that pops out, and rotating it towards the top of the laptop until the battery comes free from the laptop.
  • The battery will rotate outward by lifting the bottom lip that pops out, and rotating it towards the top of the laptop until the battery comes free from the laptop.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Hard-Drive To remove the rear-cover, flip the device on its back, and locate the screws around as illustrated *Make sure your device is powered down and unplugged before beginning the replacement.*
  • Hard-Drive
  • To remove the rear-cover, flip the device on its back, and locate the screws around as illustrated *Make sure your device is powered down and unplugged before beginning the replacement.*
  • Use a J0 bit tipped screwdriver to unscrew the 2 6 mm Phillips screws on the back panel.
Using a spudgear, Lightly lift the RAM cover up and at an angle, away from the computer. Using a spudgear, Lightly lift the RAM cover up and at an angle, away from the computer.
  • Using a spudgear, Lightly lift the RAM cover up and at an angle, away from the computer.
Hard Drive
  • Hard Drive
Remove the 4 6mm philips screws on the hard drive using the J0 bit tipped screwdriver.
  • Remove the 4 6mm philips screws on the hard drive using the J0 bit tipped screwdriver.
Lift hard drive out of the computer slightly
  • Lift hard drive out of the computer slightly
  • *Be careful not to tear the ribbon that attaches the hard drive to the computer when lifting it.
Using  two  fingers, grab the black connector on the ribbon and pull until detached. Using  two  fingers, grab the black connector on the ribbon and pull until detached.
  • Using two fingers, grab the black connector on the ribbon and pull until detached.
2 autre(s) ont terminé cette réparation.
Mitchell Roberts
Membre depuis le 23/01/2018
321 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 19
Total : 57
