Cette version peut contenir des modifications incorrectes. Passez au dernier aperçu vérifié.
Ce dont vous avez besoin
Cette étape n’est pas traduite. Aidez à la traduire
Make sure the laptop is powered down before you remove the battery.
Locate the battery release switch on the bottom of the laptop.
Slide the battery release switch away from the lock symbol towards the “unlock” position.
Rotate the battery outward by lifting the bottom lip that pops out.
Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Use a JIS #0 screwdriver to unscrew the two 6 mm screws from the back panel.
Using a spudger, lightly lift the RAM cover up and at an angle, away from the computer.
Remove the four 6 mm JIS #0 screws from the hard drive.
Using two fingers, grab the black connector on the ribbon, and pull until detached.
2 autres ont terminé cette réparation.
