Introduction
The following guide will give instructions on how to properly replace the RAM/Memory on your Dell Inspiron 15-5552.
Ce dont vous avez besoin
Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
Remove the dislodged up RAM by pulling it away from the connection.
