Aller au contenu principal
Dell Inspiron 15-5558 Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5558 Screen Replacement, Battery: étape 1, image 1 de 1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Screen Replacement: étape 2, image 1 de 1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Screen Replacement: étape 3, image 1 de 2 Dell Inspiron 15-5558 Screen Replacement: étape 3, image 2 de 2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Screen Replacement, Screen: étape 4, image 1 de 2 Dell Inspiron 15-5558 Screen Replacement, Screen: étape 4, image 2 de 2
    • Open device so it is at least opened at a 90 degree angle.
    • Wedge a spudger between the screen and the plastic frame.
    • Push in the spudger and push down to pop the frame from the pins.
    • Repeat around the whole frame.
  5. Dell Inspiron 15-5558 Screen Replacement: étape 5, image 1 de 3 Dell Inspiron 15-5558 Screen Replacement: étape 5, image 2 de 3 Dell Inspiron 15-5558 Screen Replacement: étape 5, image 3 de 3
    • Once all the pins are off, remove the frame by pulling it away from the screen.
    • Using a Phillips #0 screwdriver, unscrew the four 3mm screws holding the screen in place.
    • Push the spudger behind the screen and push down to remove the screen.
  6. Dell Inspiron 15-5558 Screen Replacement: étape 6, image 1 de 3 Dell Inspiron 15-5558 Screen Replacement: étape 6, image 2 de 3 Dell Inspiron 15-5558 Screen Replacement: étape 6, image 3 de 3
    • Pull the tape connecting the screen up with your fingers and pull the securing bar up with it.
    • Disconnect the securing bar to remove the screen.
6 autres ont terminé cette réparation.
Adam Lourenco
Membre depuis le 10/19/17
775 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G4, Bailey Fall 2017
UMASSD-BAILEY-F17S3G4
3 membres
5 tutoriels rédigés
2 commentaires
Where can I buy the screen from?
wardak_90 - Réponse
How many pins is the screen connector? 30? 40?
Adrian Lewis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 29
Total : 4,675
