Introduction
Before you attempt this guide make sure your device is not connected to a power source and be sure that the battery is removed. This guide is relatively easy and doesn't require any special skills.
Ce dont vous avez besoin
Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
Place a finger on each of the 2 metal prongs on either side of the RAM stick and apply light pressure to release the RAM stick.
Remove the first stick of RAM. Repeat this process for the second RAM stick.
