Aller au contenu principal
Dell Inspiron 15-5567 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: étape 1, image 1 de 1
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: étape 2, image 1 de 3 Dell Inspiron 15-5567 Battery Replacement: étape 2, image 2 de 3 Dell Inspiron 15-5567 Battery Replacement: étape 2, image 3 de 3
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: étape 3, image 1 de 2 Dell Inspiron 15-5567 Battery Replacement: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: étape 4, image 1 de 2 Dell Inspiron 15-5567 Battery Replacement: étape 4, image 2 de 2
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
  5. Dell Inspiron 15-5567 Battery Replacement: étape 5, image 1 de 2 Dell Inspiron 15-5567 Battery Replacement: étape 5, image 2 de 2
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
5 autres ont terminé cette réparation.
Saaed Chaudhry
Membre depuis le 07/15/20
382 Réputation
2 tutoriels rédigés
Équipe
York University, Team S1-G8, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S1-G8, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G8
1 membre
2 tutoriels rédigés
Un commentaire
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 120
Total : 7,398
