Introduction
This guide will demonstrate how to replace the battery for the Dell Inspiron 15-7559. This may be necessary if you have issues charging or turning on the device.
Turn off the computer.
  • Turn off the computer.
  • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
  • Flip the computer upside down.
Ajouter un commentaire
Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver. Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened. Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
Use the blue, plastic opening tool to gently pry a section of the back panel open. Next slide the opening tool around the back panel to disconnect the connecting pins. After the pins have been disconnected the back panel can then be easily lifted off the computer.
  • Use the blue, plastic opening tool to gently pry a section of the back panel open.
  • Next slide the opening tool around the back panel to disconnect the connecting pins.
  • After the pins have been disconnected the back panel can then be easily lifted off the computer.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Locate the battery on the bottom left side of the laptop.
  • Locate the battery on the bottom left side of the laptop.
Unscrew the 5 x 2mm x 5mm screws, using the T7 Torx screwdriver. Unscrew the 5 x 2mm x 5mm screws, using the T7 Torx screwdriver. Unscrew the 5 x 2mm x 5mm screws, using the T7 Torx screwdriver.
  • Unscrew the 5 x 2mm x 5mm screws, using the T7 Torx screwdriver.
Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it. Using your hand grab the white portion connecting the cables to the battery and disconnect it. Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
  • Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
  • Using your hand grab the white portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
Now lift the battery from the device to remove it.
  • Now lift the battery from the device to remove it.
Trenton Greevebiester
Membre depuis le 19/10/2017
723 Réputation
6 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G2, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 41
30 derniers jours : 236
Total : 830
