Introduction
This guide will demonstrate how to replace the keyboard for the Dell Inspiron 15-7559. This may be necessary if you are unable to use the keyboard.
Pièces
Aucune pièce nécessaire.
Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up. After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released. After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
  • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
Ajouter un commentaire
Now lift the keyboard enough to access the ribbon cables beneath it. Now lift the keyboard enough to access the ribbon cables beneath it.
  • Now lift the keyboard enough to access the ribbon cables beneath it.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up. Once the latch is raised, lift the ribbon cable up and out of the latch. Once the latch is raised, lift the ribbon cable up and out of the latch.
  • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
  • Once the latch is raised, lift the ribbon cable up and out of the latch.
Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
  • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
Trenton Greevebiester
Membre depuis le 19/10/2017
723 Réputation
6 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G2, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 9
7 derniers jours : 34
30 derniers jours : 139
Total : 653
