Introduction
This guide will show you how to remove the optical disc drive from your device.
Pièces
Aucune pièce nécessaire.
Place the laptop facedown with the battery facing you. Push the switch above the battery to the right and hold it in that position. Lift the battery using the grip on the top and remove it from its socket.
  • Place the laptop facedown with the battery facing you.
  • Push the switch above the battery to the right and hold it in that position.
  • Lift the battery using the grip on the top and remove it from its socket.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the JIS #1 8mm screw from above the upper right corner of where the battery was. Remove the JIS #1 8mm screw from above the upper right corner of where the battery was.
  • Remove the JIS #1 8mm screw from above the upper right corner of where the battery was.
Pull the optical drive out.
  • Pull the optical drive out.
Ravon Williams
Membre depuis le 16/04/2018
169 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G4, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G4
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 29
