Introduction
This guide will show you how to remove the memory from your device.
Pièces
Aucune pièce nécessaire.
Place the laptop facedown with the battery facing you. Push the switch above the battery to the right and hold it in that position. Lift the battery using the grip on the top and remove it from its socket.
  • Place the laptop facedown with the battery facing you.
  • Push the switch above the battery to the right and hold it in that position.
  • Lift the battery using the grip on the top and remove it from its socket.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Loosen the two JIS #1 8mm screws on the cover. Lift and remove the cover. Lift and remove the cover.
  • Loosen the two JIS #1 8mm screws on the cover.
  • Lift and remove the cover.
Pull the two metal clips holding down the card apart. Lift and pull out the card.
  • Pull the two metal clips holding down the card apart.
  • Lift and pull out the card.
Ravon Williams
Membre depuis le 16/04/2018
169 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G4, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G4
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 16
