Introduction
This guide will show you how to prepare the computer for the removal of the panel underneath the keyboard.
Pièces
Aucune pièce nécessaire.
Rotate the laptop so its bottom is facing up.
  • Rotate the laptop so its bottom is facing up.
Ajouter un commentaire
Identify the lock mechanisms holding the battery in place. Slide each button outward with your fingers to disengage the battery. Pull the battery off with your hand to separate it from the laptop.
  • Identify the lock mechanisms holding the battery in place.
  • Slide each button outward with your fingers to disengage the battery.
  • Pull the battery off with your hand to separate it from the laptop.
Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop. Remove the thirteen indicated screws with a Phillips #1 screwdriver.
  • Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop.
  • Remove the thirteen indicated screws with a Phillips #1 screwdriver.
  • With the screws removed you can now remove the panel underneath keyboard.
2 autre(s) ont terminé cette réparation.
Erik Sanchez
Membre depuis le 26/09/2012
21 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-47, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 936
