Aller au contenu principal
Dell Inspiron 1525 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1525 Display Assembly Replacement, Battery: étape 1, image 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Display Assembly Replacement: étape 2, image 1 de 2 Dell Inspiron 1525 Display Assembly Replacement: étape 2, image 2 de 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Display Assembly Replacement, Central Control Cover: étape 3, image 1 de 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Display Assembly Replacement: étape 4, image 1 de 3 Dell Inspiron 1525 Display Assembly Replacement: étape 4, image 2 de 3 Dell Inspiron 1525 Display Assembly Replacement: étape 4, image 3 de 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Display Assembly Replacement: étape 5, image 1 de 3 Dell Inspiron 1525 Display Assembly Replacement: étape 5, image 2 de 3 Dell Inspiron 1525 Display Assembly Replacement: étape 5, image 3 de 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
  6. Dell Inspiron 1525 Display Assembly Replacement, Keyboard: étape 6, image 1 de 2 Dell Inspiron 1525 Display Assembly Replacement, Keyboard: étape 6, image 2 de 2
    • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
    • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
  7. Dell Inspiron 1525 Display Assembly Replacement: étape 7, image 1 de 2 Dell Inspiron 1525 Display Assembly Replacement: étape 7, image 2 de 2
    • Use a spudger to gently lift the ribbon cable retaining flap.
    • Disconnect the ribbon cable.
    • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
  8. Dell Inspiron 1525 Display Assembly Replacement, Bottom Cover: étape 8, image 1 de 2 Dell Inspiron 1525 Display Assembly Replacement, Bottom Cover: étape 8, image 2 de 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  9. Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: étape 9, image 1 de 3 Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: étape 9, image 2 de 3 Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: étape 9, image 3 de 3
    • Disconnect the five antennas from their respective cards.
    • De-route the antennas from their routing retainers.
  10. Dell Inspiron 1525 Display Assembly Replacement: étape 10, image 1 de 1
    • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
  11. Dell Inspiron 1525 Display Assembly Replacement: étape 11, image 1 de 3 Dell Inspiron 1525 Display Assembly Replacement: étape 11, image 2 de 3 Dell Inspiron 1525 Display Assembly Replacement: étape 11, image 3 de 3
    • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
    • Carefully release the connector from its retaining tabs.
  12. Dell Inspiron 1525 Display Assembly Replacement: étape 12, image 1 de 2 Dell Inspiron 1525 Display Assembly Replacement: étape 12, image 2 de 2
    • Push the antenna wires up through their hole in the bottom case half.
    • Release the antennas from their retaining tabs on the upper case.
  13. Dell Inspiron 1525 Display Assembly Replacement: étape 13, image 1 de 2 Dell Inspiron 1525 Display Assembly Replacement: étape 13, image 2 de 2
    • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
    • Free the ribbon cable from its retaining clips.
  14. Dell Inspiron 1525 Display Assembly Replacement: étape 14, image 1 de 1
    • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
    • Remove the display assembly from the laptop.
8 autres ont terminé cette réparation.
Un commentaire
Hi There,
Thanks for the great article. Can you please advise what is the part number (LCD number). For example I have LTN156AT17-101 for my Inspiron N5110. I am actually planning to use the screen from 1525 to replace the one in N5110. Are they both same connector type? Thanks.
Zaheer Meerja - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 13
Total : 9,633
