Introduction
Use this guide to help you replace the keyboard in a Dell Inspiron 1525.
Pièces
Aucune pièce nécessaire.
Locate the battery release switch on the bottom of the laptop.
  • Locate the battery release switch on the bottom of the laptop.
Ajouter un commentaire
Slide the battery release switch away from the lock symbol until you hear the battery click. Slide the battery towards the back of the laptop until it comes free.
  • Slide the battery release switch away from the lock symbol until you hear the battery click.
  • Slide the battery towards the back of the laptop until it comes free.
Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up. Carefully pull the central control cover up along its edges. Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
  • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
Peel back the silver tape securing the ribbon cable to the cover. Pull the small brown latch on the ribbon cable connector out. Disconnect the ribbon cable to completely free the central control cover.
  • Peel back the silver tape securing the ribbon cable to the cover.
  • Pull the small brown latch on the ribbon cable connector out.
  • Disconnect the ribbon cable to completely free the central control cover.
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop. Gently slide the keyboard towards the display until the tabs on its front side are free.
  • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
  • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
Use a spudger to gently lift the ribbon cable retaining flap. Disconnect the ribbon cable.
  • Use a spudger to gently lift the ribbon cable retaining flap.
  • Disconnect the ribbon cable.
  • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
the flap broke? the little black piece. Now what do i do? I'm stuck at this step
daaaammon - Réponse
11 autre(s) ont terminé cette réparation.
why did you say to remove the central control cover? It is so hard top get it back! Especially when the guide on laptopkeyboard.com seems to suggest that this is unnecessary.
sally wise - Réponse
Thank you so much…!
amal. k.manoj - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 39
Total : 12,821
