Aller au contenu principal
Dell Inspiron 1545 Center Control Cover Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1545 Center Control Cover Replacement, Battery: étape 1, image 1 de 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Center Control Cover Replacement: étape 2, image 1 de 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Center Control Cover Replacement: étape 3, image 1 de 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Center Control Cover Replacement, Center Control Cover: étape 4, image 1 de 1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  5. Dell Inspiron 1545 Center Control Cover Replacement: étape 5, image 1 de 1
    • Flip the laptop over to the front and open the display as far as possible.
  6. Dell Inspiron 1545 Center Control Cover Replacement: étape 6, image 1 de 3 Dell Inspiron 1545 Center Control Cover Replacement: étape 6, image 2 de 3 Dell Inspiron 1545 Center Control Cover Replacement: étape 6, image 3 de 3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
2 autres ont terminé cette réparation.
Nathan Lemay
Membre depuis le 04/16/14
3 052 Réputation
15 tutoriels rédigés
Équipe
Cal Poly, Team 9-14, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 2,675
