Aller au contenu principal
Dell Inspiron 1545 Computer Processing Unit Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1545 Computer Processing Unit Replacement, Battery: étape 1, image 1 de 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Computer Processing Unit Replacement: étape 2, image 1 de 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Computer Processing Unit Replacement: étape 3, image 1 de 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Computer Processing Unit Replacement, Base Cover: étape 4, image 1 de 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Computer Processing Unit Replacement: étape 5, image 1 de 2 Dell Inspiron 1545 Computer Processing Unit Replacement: étape 5, image 2 de 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Computer Processing Unit Replacement, CPU Heat Sink: étape 6, image 1 de 1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 Computer Processing Unit Replacement: étape 7, image 1 de 1
    • Pull up on the Heat Sink unit to remove it.
  8. Dell Inspiron 1545 Computer Processing Unit Replacement, Computer Processing Unit: étape 8, image 1 de 1
    • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
  9. Dell Inspiron 1545 Computer Processing Unit Replacement: étape 9, image 1 de 1
    • The CPU is very fragile and has thin pins.
    • Remove the CPU by pulling straight upward and away from the laptop.
7 autres ont terminé cette réparation.
Nathan Lemay
Membre depuis le 04/16/14
3 052 Réputation
15 tutoriels rédigés
Équipe
Cal Poly, Team 9-14, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 24
Total : 2,624
