Introduction
This guide will most likely be utilized if one of the USB ports or auxiliary ports are unresponsive. This will cover removing the boards so the entire board can be replaced rather than unsoldering each individual port.
Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
  • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
  • Turn the laptop over to its back.
Ajouter un commentaire
Slide the release latch while simultaneously pulling backwards on the battery.
  • Slide the release latch while simultaneously pulling backwards on the battery.
Slide the battery out of the battery bay.
  • Slide the battery out of the battery bay.
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
Flip the laptop over to the front and open the display as far as possible.
  • Flip the laptop over to the front and open the display as far as possible.
The Center Control Cover is VERY fragile,  be careful when using prying tools. Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here. Carefully lift the Center Control Cover away from the laptop.
  • The Center Control Cover is VERY fragile, be careful when using prying tools.
  • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
  • Carefully lift the Center Control Cover away from the laptop.
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
  • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
  • The screws are connected to the base cover by a washer anddo not remove from the base cover.
Carefully lift the base cover vertically away from the laptop. Carefully lift the base cover vertically away from the laptop.
  • Carefully lift the base cover vertically away from the laptop.
Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
  • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
  • These screws are held in place by a washer so you should not be able to completely remove the screws.
My fifth screw, (the one towards the bottom), won't unscrew. Anybody that can help?
Michael Shirley - Réponse
Pull up on the Heat Sink unit to remove it.
  • Pull up on the Heat Sink unit to remove it.
Flip the laptop to its back side.
  • Flip the laptop to its back side.
  • Remove the screw (5mm Phillips #1) that secures the Optical Disk Drive on the back of the laptop.
Push the Optical Disk Drive out using a spudger tool as shown and pulling from the front cover of the Optical Disk Drive. Push the Optical Disk Drive out using a spudger tool as shown and pulling from the front cover of the Optical Disk Drive. Push the Optical Disk Drive out using a spudger tool as shown and pulling from the front cover of the Optical Disk Drive.
  • Push the Optical Disk Drive out using a spudger tool as shown and pulling from the front cover of the Optical Disk Drive.
Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
  • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
  • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
  • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
The connector latch is the black piece.
Maurice Volaski - Réponse
Lift the keyboard up and away from the laptop.
  • Lift the keyboard up and away from the laptop.
Remove the 11 screws (5mm Phillips #1) from the back of the laptop as marked. One screw is in the middle, by the RAM.
  • Remove the 11 screws (5mm Phillips #1) from the back of the laptop as marked. One screw is in the middle, by the RAM.
Remove black and white wires from the WLAN that lead to the display by pulling straight up.
  • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
  • Unwind the wires from the routing guides.
Turn the laptop back over to its normal resting position and pull the black and white wires previously connected to the WLAN through the hole.
  • Turn the laptop back over to its normal resting position and pull the black and white wires previously connected to the WLAN through the hole.
  • Remove the 4 smaller screws (5mm Phillips #1) and one screw on the top left (3mm Phillips #1) from the palm rest.
Disconnect the Bluetooth card cable, Wed cable, Camera1 cable, power cable, and touchpad cable from the respective Motherboard connectors as marked. For the Bluetooth cable and Camera1 cable, pull the plugs towards the screen. For the touchpad and power cable, lift the black tab and then pull them out. For the Wed cable, pull the blue tab up.
  • Disconnect the Bluetooth card cable, Wed cable, Camera1 cable, power cable, and touchpad cable from the respective Motherboard connectors as marked. For the Bluetooth cable and Camera1 cable, pull the plugs towards the screen. For the touchpad and power cable, lift the black tab and then pull them out. For the Wed cable, pull the blue tab up.
  • Unsecure the wires from the routing guides so they are loose.
  • Pull on the plastic tabs for each connector to help prevent causing damage to the connectors.
To separate the palm rest from the rest of the computer, use a plastic opening tool to lift up the plastic. It is best to start at one point and work your way around.
  • To separate the palm rest from the rest of the computer, use a plastic opening tool to lift up the plastic. It is best to start at one point and work your way around.
Remove the 3 screws (3mm Phillips #1) that secure the daughter board to the motherboard.
  • Remove the 3 screws (3mm Phillips #1) that secure the daughter board to the motherboard.
  • Lift the daughter board away from the laptop.
Remove the two screws (3mm, Phillips #1) on the left and the two screws (5mm, Phillips #1) on the right that secure the Motherboard to the laptop.
  • Remove the two screws (3mm, Phillips #1) on the left and the two screws (5mm, Phillips #1) on the right that secure the Motherboard to the laptop.
Disconnect the Thermal Fan cable, Speaker cable, and USB Board cable from their connectors.
  • Disconnect the Thermal Fan cable, Speaker cable, and USB Board cable from their connectors.
To remove the Motherboard, pull away and up from the base of the laptop.
  • To remove the Motherboard, pull away and up from the base of the laptop.
  • Along with removing the Motherboard if you haven’t already done so, the auxiliary port cover on the front will come off with it as well.
Great job. Couldn’t have done it nearly as fast without making mistakes. Thank you.
Andy Rothauser - Réponse
Remove the two screws (5mm, Phillips #1) in order to remove the main auxiliary board containing USB ports, and audio/microphone ports.
  • Remove the two screws (5mm, Phillips #1) in order to remove the main auxiliary board containing USB ports, and audio/microphone ports.
There is another USB board on the right side of the laptop. To remove this simply remove the two screws (5mm, Phillips #1) and lift the port up.
  • There is another USB board on the right side of the laptop. To remove this simply remove the two screws (5mm, Phillips #1) and lift the port up.
5 autre(s) ont terminé cette réparation.
Nathan Lemay
Membre depuis le 16/04/2014
2 491 Réputation
15 tutoriels rédigés
Équipe
Cal Poly, Team 9-14, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 membres
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 64
Total : 2,836
