Introduction
Follow this guide if your disk drive is damaged and needs replacement.
Pièces
Aucune pièce nécessaire.
Unplug the laptop before changing the battery to avoid electric shock. Place the laptop on a flat stable surface.
  • Unplug the laptop before changing the battery to avoid electric shock.
  • Place the laptop on a flat stable surface.
  • Flip the laptop over so the underside is visible.
Ajouter un commentaire
Locate the battery lock switch. Slide the lock switch to the left (away from the lock symbol).
  • Locate the battery lock switch.
  • Slide the lock switch to the left (away from the lock symbol).
  • Slide the battery out away from the laptop.
Remove the 2mm Phillips #00 screw next to the module cover. Pull the disc drive away from the laptop.
  • Remove the 2mm Phillips #00 screw next to the module cover.
  • Pull the disc drive away from the laptop.
2 autre(s) ont terminé cette réparation.
Tina Rickard
Membre depuis le 07/04/2014
686 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-3, Forte Spring 2014 Membre de l'équipe Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 622
