Introduction
If you're having issues with your monitor, you'll most likely need to replace it. Due to the fact that the monitor is one assembly, if a new issue occurs with your screen you'll need to replace the entire screen.
To replace the monitor, you'll need to disassemble most of the laptop.
Pièces
Aucune pièce nécessaire.
Make sure the laptop is off before attempting to remove the battery.
  • Make sure the laptop is off before attempting to remove the battery.
  • Flip over your laptop so that the battery faces you.
Ajouter un commentaire
Slide each latch away from the battery to unlock it. Slide each latch away from the battery to unlock it.
  • Slide each latch away from the battery to unlock it.
Lift the battery upwards to remove it. Continue holding the latches when removing the battery.
  • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
Remove one 4.8mm screw with a JIS #00 screwdriver. Remove the optical drive.
  • Remove one 4.8mm screw with a JIS #00 screwdriver.
  • Remove the optical drive.
Remove two 4.8mm screws with a JIS #00 screwdriver.
  • Remove two 4.8mm screws with a JIS #00 screwdriver.
  • Remove the access panel.
Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver. Slide the hard drive to the left. Slide the hard drive to the right and up.
  • Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
  • Slide the hard drive to the left.
  • Slide the hard drive to the right and up.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Slide the two clips away from the RAM. Lift the RAM out.
  • Slide the two clips away from the RAM.
  • Lift the RAM out.
A metal spudger can scratch delicate internal parts. Be extra careful when removing the keyboard.
  • A metal spudger can scratch delicate internal parts. Be extra careful when removing the keyboard.
  • Use a metal spudger to loosen the main frame of the keyboard.
    • A metal spudger should be used instead of a plastic one because a plastic one will probably break.
    • Make sure to get the spudger under the entire keyboard and not just under the keys.
Slowly lift the keyboard. Lift the locking flap that holds the ribbon cable in place. The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap.
  • Slowly lift the keyboard.
  • Lift the locking flap that holds the ribbon cable in place.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap.
  • Remove the keyboard.
Remove two 1.6mm screws from beneath the optical drive with a JIS #00 screwdriver. Remove the eight remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver. Remove the eight remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver.
  • Remove two 1.6mm screws from beneath the optical drive with a JIS #00 screwdriver.
  • Remove the eight remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver.
Remove the two exposed ribbon cables. Remove the palmrest. Remove the palmrest.
  • Remove the two exposed ribbon cables.
  • Remove the palmrest.
Remove the display cable on the top-right of the motherboard. Ensure the cable snakes through the path in the case when putting it  back together. Remove the two antennae from Wi-Fi chip.
  • Remove the display cable on the top-right of the motherboard.
    • Ensure the cable snakes through the path in the case when putting it back together.
  • Remove the two antennae from Wi-Fi chip.
Remove the nine 4.8mm screws from the hinges. There are four on the right and five on the left with a JIS #00 screwdriver. Lift the display assembly away from the base. Lift the display assembly away from the base.
  • Remove the nine 4.8mm screws from the hinges. There are four on the right and five on the left with a JIS #00 screwdriver.
  • Lift the display assembly away from the base.
Unsnap the bezel around the edges.
  • Unsnap the bezel around the edges.
  • Remove the bezel.
  • During reassembly, make sure the wires are tucked inside the hinges so that they fit around the edges.
Remove the one 4.8mm screw from each hinge cover with a JIS #00 screwdriver. Do not over-tighten these screws during reassembly, as the hinge cover is thin and may break.
  • Remove the one 4.8mm screw from each hinge cover with a JIS #00 screwdriver.
    • Do not over-tighten these screws during reassembly, as the hinge cover is thin and may break.
  • Remove the hinge cover.
Remove the five 4.8mm screws from each hinge with a JIS #00 screwdriver. Remove one 4.8mm screw from the top left and the top right of the screen with a JIS #00 screwdriver. Remove one 4.8mm screw from the top left and the top right of the screen with a JIS #00 screwdriver.
  • Remove the five 4.8mm screws from each hinge with a JIS #00 screwdriver.
  • Remove one 4.8mm screw from the top left and the top right of the screen with a JIS #00 screwdriver.
Be sure not to damage the display cable when lifting the screen! Slowly lift the screen away from the case assembly. Unplug the display cable from the back of the screen.
  • Be sure not to damage the display cable when lifting the screen!
  • Slowly lift the screen away from the case assembly.
  • Unplug the display cable from the back of the screen.
  • Make sure there are no cables under the screen during reassembly.
Remove the four 3.2mm screws from each rail with a JIS #00 screwdriver. Remove the rails from the screen. Remove the rails from the screen.
  • Remove the four 3.2mm screws from each rail with a JIS #00 screwdriver.
  • Remove the rails from the screen.
David Callahan
Membre depuis le 19/10/2017
513 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G7, Bailey Fall 2017
UMASSD-BAILEY-F17S3G7
3 membres
11 tutoriels rédigés
I was able to do this repair on this exact model of laptop without dismantling the bottom half of the laptop. It’s not hard at all, all you’ve got to do is just separate the bezel from the lid of the laptop and pull it out from behind the base. It saves lots of trouble of dismantling. You can’t replace the hinges this way, though, but you can certainly replace the LCD itself without dismantling the bottom half of the laptop.
Joseph Sctbunio - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 29
Total : 140
