Aller au contenu principal
Dell Inspiron 5379 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 5379 Hard Drive Replacement, Peeling the Tape: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Peel off the tape that secures the hard-drive cable to the palm-rest assembly.
  2. Dell Inspiron 5379 Hard Drive Replacement, Disconnecting the Hard Drive Cable: étape 2, image 1 de 1
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 5379 Hard Drive Replacement, Remove the Screws: étape 3, image 1 de 1
    • Remove the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
  4. Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 4, image 1 de 1
    • Lift the hard-drive assembly, along with its cable, off the palm-rest assembly.
  5. Dell Inspiron 5379 Hard Drive Replacement, Disconnecting the Interposer: étape 5, image 1 de 1
    • Disconnect the interposer from the hard-drive assembly.
  6. Dell Inspiron 5379 Hard Drive Replacement, Remove the Screws: étape 6, image 1 de 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Bracket: étape 7, image 1 de 2 Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Bracket: étape 7, image 2 de 2
    • Lift the hard-drive bracket off the hard drive.
  8. Dell Inspiron 5379 Hard Drive Replacement, Align the Screw Holes: étape 8, image 1 de 1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 5379 Hard Drive Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 5379 Hard Drive Replacement, Connecting the Interposer: étape 10, image 1 de 1
    • Connect the interposer to the hard-drive assembly.
  11. Dell Inspiron 5379 Hard Drive Replacement, Align the Screw Holes: étape 11, image 1 de 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  12. Dell Inspiron 5379 Hard Drive Replacement, Replace the Screws: étape 12, image 1 de 1
    • Replace the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
  13. Dell Inspiron 5379 Hard Drive Replacement, Connecting the Hard-Drive Cable: étape 13, image 1 de 1
    • Connect the hard-drive cable to the system board.
  14. Dell Inspiron 5379 Hard Drive Replacement, Adhering the Tape: étape 14, image 1 de 1
    • Adhere the tape that secures the hard-drive cable to the palm-rest assembly.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 11
Total : 2,066
