Introduction
Before removing the RAM you will need to remove your battery.
Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily.
  • Push in the tab on the battery and lift up. The battery should detach very easily.
Ajouter un commentaire
Remove the single screw securing the RAM compartment and pull up to reveal the RAM. Remove the single screw securing the RAM compartment and pull up to reveal the RAM. Remove the single screw securing the RAM compartment and pull up to reveal the RAM.
  • Remove the single screw securing the RAM compartment and pull up to reveal the RAM.
Push on the small white metal tabs on both sides of a module to unlock it. The RAM should be stick out at approximately a 45 degree angle. Grasp the RAM by the sides and pull straight out to remove it. If the RAM sticks slightly, wiggle it back and forth gently to loosen it.
  • Push on the small white metal tabs on both sides of a module to unlock it.
  • The RAM should be stick out at approximately a 45 degree angle. Grasp the RAM by the sides and pull straight out to remove it.
    • If the RAM sticks slightly, wiggle it back and forth gently to loosen it.
Taylor Woods
Membre depuis le 05/04/2011
101 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-40, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 3,573
