Aller au contenu principal
Dell Inspiron 600m Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 600m Hard Drive Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 600m Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: étape 2, image 1 de 1
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: étape 3, image 1 de 1
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: étape 4, image 1 de 1
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
7 autres ont terminé cette réparation.
Todd
Membre depuis le 04/05/11
146 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-40, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 membres
8 tutoriels rédigés
2 commentaires
What size is the hard drive, you know, to buy a new one?
Ethan White - Réponse
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 32
Total : 17,216
