Introduction
The 700m has room for two sticks of RAM, but one is hidden under the keyboard. Use this guide to replace both.
Pièces
Aucune pièce nécessaire.
Before you begin, make sure the 700m is powered off.
  • Before you begin, make sure the 700m is powered off.
  • Unplug the power cable.
  • Flip the 700m over and remove the battery.
    • Slide the battery release switch toward the center of the 700m, and then pull the battery free from the back.
Ajouter un commentaire
Remove the two Phillips screws securing the RAM cover.
  • Remove the two Phillips screws securing the RAM cover.
  • Remove the RAM cover and set it aside.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module. When released, the RAM module will pop up at a slight angle. Lift the RAM module to an angle of about 30 degrees and slide it out.
  • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
  • Lift the RAM module to an angle of about 30 degrees and slide it out.
    • When handling the RAM module, touch only the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM module, slide it in place at about the same angle until it is snug, and then swing it downward until the two clips snap into place.
Flip the 700m over and swing the screen all the way open until it lays flat. Beginning from the left side, use the flat end of a spudger to gently pry up the plastic trim that runs along the top edge of the keyboard. Remove the trim. Beginning from the left side, use the flat end of a spudger to gently pry up the plastic trim that runs along the top edge of the keyboard. Remove the trim.
  • Flip the 700m over and swing the screen all the way open until it lays flat.
  • Beginning from the left side, use the flat end of a spudger to gently pry up the plastic trim that runs along the top edge of the keyboard. Remove the trim.
Remove the two Phillips screws securing the keyboard.
  • Remove the two Phillips screws securing the keyboard.
Tilt the top of the keyboard up at an angle, and gently push the keyboard toward the back of the 700m, freeing the tabs along the bottom.
  • Tilt the top of the keyboard up at an angle, and gently push the keyboard toward the back of the 700m, freeing the tabs along the bottom.
    • Do not push very hard, or you may damage the keyboard ribbon cable.
Tilt the bottom of the keyboard up at an angle. Use the pointed end of a spudger to disconnect the keyboard ribbon cable by pushing open the clips on either side. Remove the keyboard and set it aside.
  • Tilt the bottom of the keyboard up at an angle.
  • Use the pointed end of a spudger to disconnect the keyboard ribbon cable by pushing open the clips on either side.
  • Remove the keyboard and set it aside.
Remove the two Phillips screws securing the inner RAM cover. Tilt the right side of the RAM cover up at an angle and pull it free.
  • Remove the two Phillips screws securing the inner RAM cover.
  • Tilt the right side of the RAM cover up at an angle and pull it free.
3 autre(s) ont terminé cette réparation.
Jeff Suovanen
Membre depuis le 06/08/2013
156 474 Réputation
390 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
116 membres
5 774 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 22
Total : 2,532
