Introduction
First you must remove the hinge cover than keyboard lower case and finally have access to the cooling fan.
Pièces
Aucune pièce nécessaire.
Remove the battery from the bottom of the laptop.
  • Remove the battery from the bottom of the laptop.
  • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
  • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
Ajouter un commentaire
Remove the screws on the top right of the bottom of the laptop. Once screws are removed, the fan can easily be slid out of its position. Once screws are removed, the fan can easily be slid out of its position.
  • Remove the screws on the top right of the bottom of the laptop.
  • Once screws are removed, the fan can easily be slid out of its position.
John Nesthus
Membre depuis le 13/04/2011
183 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 18-22, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 membres
15 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 3,092
