Aller au contenu principal
Dell Inspiron 8600 Display Removal
Ce dont vous avez besoin
  1. Dell Inspiron 8600 Display Removal, Battery: étape 1, image 1 de 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Display Removal, Hinge Cover: étape 2, image 1 de 3 Dell Inspiron 8600 Display Removal, Hinge Cover: étape 2, image 2 de 3 Dell Inspiron 8600 Display Removal, Hinge Cover: étape 2, image 3 de 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Display Removal: étape 3, image 1 de 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Display Removal, Display Module: étape 4, image 1 de 2 Dell Inspiron 8600 Display Removal, Display Module: étape 4, image 2 de 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Display Removal: étape 5, image 1 de 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Display Removal: étape 6, image 1 de 2 Dell Inspiron 8600 Display Removal: étape 6, image 2 de 2
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Display Removal: étape 7, image 1 de 1
    • Now remove the display module.
2 autres ont terminé cette réparation.
Victor
Membre depuis le 04/06/11
187 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-22, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 3,867
