Aller au contenu principal
Dell Inspiron 8600 Lower Case Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 8600 Lower Case Replacement, Battery: étape 1, image 1 de 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: étape 2, image 1 de 3 Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: étape 2, image 2 de 3 Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: étape 2, image 3 de 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Lower Case Replacement: étape 3, image 1 de 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Lower Case Replacement, Keyboard: étape 4, image 1 de 3 Dell Inspiron 8600 Lower Case Replacement, Keyboard: étape 4, image 2 de 3 Dell Inspiron 8600 Lower Case Replacement, Keyboard: étape 4, image 3 de 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Lower Case Replacement, Display Module: étape 5, image 1 de 2 Dell Inspiron 8600 Lower Case Replacement, Display Module: étape 5, image 2 de 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Lower Case Replacement: étape 6, image 1 de 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Lower Case Replacement: étape 7, image 1 de 2 Dell Inspiron 8600 Lower Case Replacement: étape 7, image 2 de 2
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Lower Case Replacement: étape 8, image 1 de 1
    • Now remove the display module.
  9. Dell Inspiron 8600 Lower Case Replacement, Lower Case: étape 9, image 1 de 1
    • Remove the two screws holding down the upper case with a Phillips #1 screwdriver.
  10. Dell Inspiron 8600 Lower Case Replacement: étape 10, image 1 de 2 Dell Inspiron 8600 Lower Case Replacement: étape 10, image 2 de 2
    • Using a Phillips #1 screwdriver, remove four screws attaching the metal bar to the motherboard.
    • Remove the metal bar which connects the motherboard to the lower case.
  11. Dell Inspiron 8600 Lower Case Replacement: étape 11, image 1 de 1
    • Disconnect the optical disk drive by gently pulling upward on the plastic connector to prevent connection damage.
  12. Dell Inspiron 8600 Lower Case Replacement: étape 12, image 1 de 3 Dell Inspiron 8600 Lower Case Replacement: étape 12, image 2 de 3 Dell Inspiron 8600 Lower Case Replacement: étape 12, image 3 de 3
    • Remove the optical disc drive by pushing a small release button on the side of the laptop and then pulling it.
    • This will uncover one final screw. Use the Phillips # 1 to remove the screw.
  13. Dell Inspiron 8600 Lower Case Replacement: étape 13, image 1 de 1
    • Now, pop off the lower case for repair or replacement.
John Nesthus
Membre depuis le 04/13/11
186 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 18-22, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 20
Total : 3,544
