Aller au contenu principal
Dell Inspiron 8600 Power Button Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 8600 Power Button Replacement, Battery: étape 1, image 1 de 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Power Button Replacement, Power Button: étape 2, image 1 de 3 Dell Inspiron 8600 Power Button Replacement, Power Button: étape 2, image 2 de 3 Dell Inspiron 8600 Power Button Replacement, Power Button: étape 2, image 3 de 3
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Power Button Replacement: étape 3, image 1 de 1
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
3 autres ont terminé cette réparation.
Brian Murphy
Membre depuis le 04/13/11
368 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-22, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 4,107
