Introduction
In this guide it will be demonstrated how to replace the memory on a Dell Inspiron 910 laptop.
Pièces
Aucune pièce nécessaire.
Turn the laptop over to where the battery is facing upwards and towards you.
  • Turn the laptop over to where the battery is facing upwards and towards you.
  • Locate the release tabs located on either side of the battery.
  • Push the release tabs toward the center of the device.
  • Remove the battery.
Ajouter un commentaire
Take the replacement battery, insert it into the original position  in the laptop.
  • Take the replacement battery, insert it into the original position in the laptop.
  • Slide the release tabs back into place.
Remember to power off the device before starting!
  • Remember to power off the device before starting!
  • Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
  • Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
  • Unscrew both of the screws using a Philips Screwdriver.
Remove the panel by pulling upward.
  • Remove the panel by pulling upward.
    • Removal may require some force!
After removing the panel, locate the memory modules. Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
  • After removing the panel, locate the memory modules.
  • Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
  • Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
    • Congratulations! You have completed the guide.
4 autre(s) ont terminé cette réparation.
Kyle Beekman
Membre depuis le 05/04/2012
141 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-10, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 2,339
