Introduction
This guide requires a Phillips #00 screwdriver
Pièces
Aucune pièce nécessaire.
Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
  • Unplug the laptop from the power adapter and turn the power off.
  • Failure to unplug laptop before proceeding could result in risk of electric shock!
Ajouter un commentaire
Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
  • Slide the battery-lock tab and hold.
  • Flip the battery away from the chassis to remove it.
Undo the two screws on the fan cover plate labeled "F3", they will remain in the panel. These screws will remain in the panel Lift up on the side of the fan nearest the screws to release the fan module
  • Undo the two screws on the fan cover plate labeled "F3", they will remain in the panel.
  • These screws will remain in the panel
  • Lift up on the side of the fan nearest the screws to release the fan module
charlierefvem
Membre depuis le 11/01/2011
854 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 13-2, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,857
