Aller au contenu principal
Dell Inspiron 9100 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 9100 Keyboard Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 9100 Keyboard Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 9100 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Keyboard Replacement: étape 2, image 1 de 3 Dell Inspiron 9100 Keyboard Replacement: étape 2, image 2 de 3 Dell Inspiron 9100 Keyboard Replacement: étape 2, image 3 de 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Turn the laptop around.
  4. Dell Inspiron 9100 Keyboard Replacement: étape 4, image 1 de 3 Dell Inspiron 9100 Keyboard Replacement: étape 4, image 2 de 3 Dell Inspiron 9100 Keyboard Replacement: étape 4, image 3 de 3
    • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
    • Fold the screen back to 180 degrees.
    • Using your index fingers, pull up the hinge cover.
  5. Dell Inspiron 9100 Keyboard Replacement: étape 5, image 1 de 3 Dell Inspiron 9100 Keyboard Replacement: étape 5, image 2 de 3 Dell Inspiron 9100 Keyboard Replacement: étape 5, image 3 de 3
    • After the hinges pop, pull the hinge cover gently.
    • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
  6. Dell Inspiron 9100 Keyboard Replacement: étape 6, image 1 de 1
    • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
  7. Dell Inspiron 9100 Keyboard Replacement: étape 7, image 1 de 3 Dell Inspiron 9100 Keyboard Replacement: étape 7, image 2 de 3 Dell Inspiron 9100 Keyboard Replacement: étape 7, image 3 de 3
    • Tilt the keyboard away from the screen.
    • Pull up on the white tab underneath the keyboard to release the keyboard.
Ana
Membre depuis le 01/11/11
111 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-2, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 3,951
