Aller au contenu principal
Dell Inspiron 9100 Memory Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 9100 Memory Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 9100 Memory Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 9100 Memory Replacement, Battery: étape 1, image 3 de 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Memory Replacement: étape 2, image 1 de 3 Dell Inspiron 9100 Memory Replacement: étape 2, image 2 de 3 Dell Inspiron 9100 Memory Replacement: étape 2, image 3 de 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Memory Replacement, Memory: étape 3, image 1 de 2 Dell Inspiron 9100 Memory Replacement, Memory: étape 3, image 2 de 2
    • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
    • This screw will remain in the panel.
    • Pull the cover away from the laptop using your finger.
  4. Dell Inspiron 9100 Memory Replacement: étape 4, image 1 de 3 Dell Inspiron 9100 Memory Replacement: étape 4, image 2 de 3 Dell Inspiron 9100 Memory Replacement: étape 4, image 3 de 3
    • Use your fingertips to carefully spread apart the plastic white tabs.
    • Flip the RAM up at a 45 degree angle and remove it.
    • Hold the RAM by the edges only.
    • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
  5. Dell Inspiron 9100 Memory Replacement: étape 5, image 1 de 1
    • Repeat step four with the second RAM.
charlierefvem
Membre depuis le 01/11/11
854 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 13-2, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 3,493
