Introduction
Before taking apart your computer at home be sure that your problem cannot be resolved using our troubleshooting guide for this item, or that it is a problem that does not require disassembly.
Pièces
Aucune pièce nécessaire.
Make sure that the computer is turned off and is disconnected from external power source.
  • Make sure that the computer is turned off and is disconnected from external power source.
  • Turn it upside down and locate the battery release switch.
Introduction: Parts: Need to add the Fan Part Numbers
Original equipment: CPU Fan DC28A000820, GPU Fan DC28A000920
John Frazier - Réponse
While holding the switch in the open position, lift out the battery. If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  • While holding the switch in the open position, lift out the battery.
  • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
Ajouter un commentaire
Locate and remove the screw shown
  • Locate and remove the screw shown
    • It is labeled with a lock symbol
Use the screwdriver to gently push the optical drive out Use the screwdriver to gently push the optical drive out
  • Use the screwdriver to gently push the optical drive out
3 autre(s) ont terminé cette réparation.
Evan Fairchild
Membre depuis le 05/10/2010
571 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 22-5, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 3,575
