Pièces
Aucune pièce nécessaire.
Make sure laptop is powered off before  removing the battery. Slide both arrow tabs towards the outer edge of the computer to release the battery.
  • Make sure laptop is powered off before removing the battery.
  • Slide both arrow tabs towards the outer edge of the computer to release the battery.
  • Note: battery is not shown.
Ajouter un commentaire
Remove Keyboard retaining screw from bottom of laptop.
  • Remove Keyboard retaining screw from bottom of laptop.
Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer. There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up. There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
  • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
"There are a number of screws on the bottom that required to be removed prior"
That's a very unhelpful step! What are they and which ones?!? I'm following two YouTube videos that show this stage and both have a single screw that holds the keyboard im place which my N5010 simply doesn't have. So my keyboard is held in place and I can't lift it.
Melvyn Mildiner - Réponse
Melvyn, I agree. This not up to iFixit's standards.
David Maag - Réponse
I have only discovered one screw that releases the keyboard. It is under the RAM access panel
Lift the keyboard up slightly and push forward in order to release bottom tabs.
  • Lift the keyboard up slightly and push forward in order to release bottom tabs.
Pull the black tab up and then pull left on keyboard plug to release keyboard.
  • Pull the black tab up and then pull left on keyboard plug to release keyboard.
Flip the laptop, so the bottom of the laptop is facing up.
  • Flip the laptop, so the bottom of the laptop is facing up.
  • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
Flip the laptop back over, so that the top of the laptop is facing up. Open the laptop.
  • Flip the laptop back over, so that the top of the laptop is facing up.
  • Open the laptop.
  • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
Carefully unsnap and remove the palm rest. Place your fingers inside the large circle in the lower right corner to get a good grip. Place your fingers inside the large circle in the lower right corner to get a good grip.
  • Carefully unsnap and remove the palm rest.
  • Place your fingers inside the large circle in the lower right corner to get a good grip.
Remove the 4 mm Hard Drive screws with the Phillips #000 screwdriver.
  • Remove the 4 mm Hard Drive screws with the Phillips #000 screwdriver.
Flip laptop over. Open lap top.
  • Flip laptop over.
  • Open lap top.
  • Pull the clear tab attached to the hard drive and gently lift up the hard drive.
11 autre(s) ont terminé cette réparation.
Sydney Moseley
Membre depuis le 13/10/2014
422 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 1-5, Benson Fall 2014 Membre de l'équipe Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 89
Total : 7,073
