Pièces
Aucune pièce nécessaire.
Make sure laptop is powered off before  removing the battery. Slide both arrow tabs towards the outer edge of the computer to release the battery.
  • Make sure laptop is powered off before removing the battery.
  • Slide both arrow tabs towards the outer edge of the computer to release the battery.
  • Note: battery is not shown.
Ajouter un commentaire
Remove Keyboard retaining screw from bottom of laptop.
  • Remove Keyboard retaining screw from bottom of laptop.
Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer. There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up. There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
  • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
"There are a number of screws on the bottom that required to be removed prior"
That's a very unhelpful step! What are they and which ones?!? I'm following two YouTube videos that show this stage and both have a single screw that holds the keyboard im place which my N5010 simply doesn't have. So my keyboard is held in place and I can't lift it.
Melvyn Mildiner - Réponse
Melvyn, I agree. This not up to iFixit's standards.
David Maag - Réponse
I have only discovered one screw that releases the keyboard. It is under the RAM access panel
Lift the keyboard up slightly and push forward in order to release bottom tabs.
  • Lift the keyboard up slightly and push forward in order to release bottom tabs.
Pull the black tab up and then pull left on keyboard plug to release keyboard.
  • Pull the black tab up and then pull left on keyboard plug to release keyboard.
April Poucher
Membre depuis le 13/10/2014
1 149 Réputation
10 tutoriels rédigés
Équipe
Clemson, Team 1-5, Benson Fall 2014 Membre de l'équipe Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 295
