Remove the battery
  • Remove the battery
Ajouter un commentaire
Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
  • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
  • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
  • Gently lift up the keyboard starting at the top of the frame
  • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
  • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
  • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
Marie K Bordley
Membre depuis le 30/09/2014
177 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-1, Buehl Fall 2014 Membre de l'équipe Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 36
Total : 2,349
