Introduction
Removal and replacement of the top cover gives access to many components. The top cover also includes the track pad assembly. This guide is often a prerequisite to replacing many internal components.
Make sure the laptop is not plugged into any wall outlets or the charger
  • Make sure the laptop is not plugged into any wall outlets or the charger
  • Unlock the battery by sliding the right-hand switch to the right.
Ajouter un commentaire
While holding the left-hand switch to the left position, pull the battery away from the laptop. While holding the left-hand switch to the left position, pull the battery away from the laptop.
  • While holding the left-hand switch to the left position, pull the battery away from the laptop.
The battery is now fully removed and the laptop will not power on without it.
  • The battery is now fully removed and the laptop will not power on without it.
Using the #0 Philips head, unscrew the indicated screw. Carefully pull  the RAM cover up and away. Carefully pull  the RAM cover up and away.
  • Using the #0 Philips head, unscrew the indicated screw.
  • Carefully pull the RAM cover up and away.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Unscrew the indicated 5.7mm screw beneath the RAM Cover.
  • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away. Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
  • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop. Be careful not to put stress on the ribbon cable below.
  • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
  • Be careful not to put stress on the ribbon cable below.
Carefully unclip the ribbon cable by tipping the keyboard towards the screen. The keyboard is now completely disconnected.
  • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
  • The keyboard is now completely disconnected.
Remove the indicated 5.7mm screws. Remove the smaller 3mm screws from underneath the battery compartment.
  • Remove the indicated 5.7mm screws.
  • Remove the smaller 3mm screws from underneath the battery compartment.
With a plastic spudger, pry away the silver top cover from the black casing. Move the tool to the right and left along the seams to fully disconnect the cover.
  • With a plastic spudger, pry away the silver top cover from the black casing.
  • Move the tool to the right and left along the seams to fully disconnect the cover.
Disconnect the indicated ribbon cables underneath where the keyboard sits.
  • Disconnect the indicated ribbon cables underneath where the keyboard sits.
Lift the cover upwards and away from the body of the laptop
  • Lift the cover upwards and away from the body of the laptop
Jonathan Sellier
Membre depuis le 26/09/2017
811 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team S13-G5, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 24
Total : 78
