Introduction
WiFi & Blue-tooth mini PCI card replacement. To change the Wifi card on this model you must to remove the upper case of the laptop. This is not a good engineering designee. We will show you how to do this.
Please SUBSCRIBE to my channel ツ
Vidéo d'introduction
Switch off the laptop and remove the battery. The keyboard is held by 4x locking clips. By using cutter, carefully lift up the one side of the keyboard and start opening the locking clips.
  • Switch off the laptop and remove the battery.
  • The keyboard is held by 4x locking clips.
  • By using cutter, carefully lift up the one side of the keyboard and start opening the locking clips.
Ajouter un commentaire
Disconnect the keyboard cable and remove the keyboard. Remove the access door screw and the access door Remove the screw securing the optical drive, and remove the optical drive
  • Disconnect the keyboard cable and remove the keyboard.
  • Remove the access door screw and the access door
  • Remove the screw securing the optical drive, and remove the optical drive
Remove all the screws Pry the upper plastic casing off of the laptop Pry the upper plastic casing off of the laptop
  • Remove all the screws
  • Pry the upper plastic casing off of the laptop
Here is the Wi-Fi card Disconnect the antenna cable connectors Remove the Wi-Fi card
Is the bios whitelist free?, I want to put an intel AC wifi card
Eduardo Arteaga - Réponse
4 autre(s) ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
153 013 Réputation
430 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
277 membres
724 tutoriels rédigés
Great, cogent step by step. You alleviated the need to watch a video while including all of the key steps. Nicely done. I replaced a hard drive last year and I would have preferred this format.
Robert Gemkow - Réponse
Hi, do you know if there is a whitelist for wifi adapters in this notebook?
Artem White - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 53
Total : 4,863
