Aller au contenu principal
Dell Latitude 7390 SSD Replacement
Ce dont vous avez besoin
  1. Dell Latitude 7390 SSD Replacement, Bottom Panel: étape 1, image 1 de 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 SSD Replacement: étape 2, image 1 de 3 Dell Latitude 7390 SSD Replacement: étape 2, image 2 de 3 Dell Latitude 7390 SSD Replacement: étape 2, image 3 de 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 SSD Replacement: étape 3, image 1 de 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 SSD Replacement: étape 4, image 1 de 2 Dell Latitude 7390 SSD Replacement: étape 4, image 2 de 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 SSD Replacement: étape 5, image 1 de 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 SSD Replacement, Battery: étape 6, image 1 de 1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 SSD Replacement: étape 7, image 1 de 3 Dell Latitude 7390 SSD Replacement: étape 7, image 2 de 3 Dell Latitude 7390 SSD Replacement: étape 7, image 3 de 3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 SSD Replacement: étape 8, image 1 de 1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 SSD Replacement, Solid State Drive (SSD): étape 9, image 1 de 1
    • Using a Phillips screwdriver, remove the 6 mm screw from the SSD cover.
  10. Dell Latitude 7390 SSD Replacement: étape 10, image 1 de 1
    • Remove the SSD card from under the silver plate.
Thomas Pryor
Membre depuis le 02/22/22
86 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 1-4, Hunter Spring 2022 Membre de l'équipe Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 21
30 derniers jours : 88
Total : 2,757
