Aller au contenu principal
Dell Latitude 7420 Battery Replacement
Ce dont vous avez besoin
  1. Dell Latitude 7420 Battery Replacement, Back Case: étape 1, image 1 de 3 Dell Latitude 7420 Battery Replacement, Back Case: étape 1, image 2 de 3 Dell Latitude 7420 Battery Replacement, Back Case: étape 1, image 3 de 3
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Battery Replacement, Battery: étape 2, image 1 de 2 Dell Latitude 7420 Battery Replacement, Battery: étape 2, image 2 de 2
    • Be sure to use an anti-static band or mat from this point onward.
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws securing the battery to the motherboard.
  3. Dell Latitude 7420 Battery Replacement: étape 3, image 1 de 2 Dell Latitude 7420 Battery Replacement: étape 3, image 2 de 2
    • Use a spudger to pry up each side. Then, lift the connector straight up from its socket.
    • To reinstall, carefully position the connector, and then press it straight down until it snaps into its socket. Finger pressure is all that is required. If it won't snap home it'll be because it isn't correctly positioned. Sometimes it can take a little patience to find exactly the right position.
  4. Dell Latitude 7420 Battery Replacement: étape 4, image 1 de 1
    • Gently remove the battery from its housing.
Xaiven Watson-torres
Membre depuis le 02/02/23
97 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-2, Pee Spring 2023 Membre de l'équipe Gateway, Team 1-2, Pee Spring 2023
GCC-PEE-S23S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 47
Total : 497
