Pièces
Aucune pièce nécessaire.
Remove the 6 screws underneath the rubber things - located in red
  • Remove the 6 screws underneath the rubber things - located in red
Ajouter un commentaire
Use your spudger to pry off the front case Go all around the perimeter and pop it off
  • Use your spudger to pry off the front case
  • Go all around the perimeter and pop it off
Remove the 6 screws holding in the display screen
  • Remove the 6 screws holding in the display screen
Remove the screw holding in the display cable conenctor Pull the black tab up to remove the display cable connector Pull the black tab up to remove the display cable connector
  • Remove the screw holding in the display cable conenctor
  • Pull the black tab up to remove the display cable connector
Slowly Remove the wire from the joints holding it in
  • Slowly Remove the wire from the joints holding it in
The computer is happy you are fixing him Thats it, display is now removed feel free to replace it by doing the steps in reverse
  • The computer is happy you are fixing him
  • Thats it, display is now removed feel free to replace it by doing the steps in reverse
Joseph
Membre depuis le 16/07/2014
1 373 Réputation
6 tutoriels rédigés
I see you removed the keyboard by seeing it in the background of the last image however, I do not see the steps instructing everyone on how to remove the keyboard.
Darren - Réponse
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 23
Total : 1,248
