Introduction
Replacing the intel wireless card, available for around 5 dollars on ebay
Outils
Aucun outil requis.
Find the battery
  • Find the battery
Ajouter un commentaire
Pull the tab to release the battery Pull the tab to release the battery
  • Pull the tab to release the battery
Pull the battery out
  • Pull the battery out
Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
Pull off the two wires connected to the wireless card
  • Pull off the two wires connected to the wireless card
  • They should come off fairly easy
Pull the two tabs away from the card and pull up on the intel card Then pull it away from the holding slot to remove it
  • Pull the two tabs away from the card and pull up on the intel card
  • Then pull it away from the holding slot to remove it
When placing in your new wireless card, connect the two wires before inserting into the slot Then line it up, put the card in at an angle and push down so the side tabs lock it into place
  • When placing in your new wireless card, connect the two wires before inserting into the slot
  • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
5 autre(s) ont terminé cette réparation.
Joseph
Membre depuis le 16/07/2014
1 373 Réputation
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 1,858
