Aller au contenu principal
Dell Latitude D610 Fan Replacement
Ce dont vous avez besoin
  1. Dell Latitude D610 Fan Replacement, Battery: étape 1, image 1 de 2 Dell Latitude D610 Fan Replacement, Battery: étape 1, image 2 de 2
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Fan Replacement: étape 2, image 1 de 3 Dell Latitude D610 Fan Replacement: étape 2, image 2 de 3 Dell Latitude D610 Fan Replacement: étape 2, image 3 de 3
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Fan Replacement: étape 3, image 1 de 1
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Fan Replacement, Keyboard: étape 4, image 1 de 3 Dell Latitude D610 Fan Replacement, Keyboard: étape 4, image 2 de 3 Dell Latitude D610 Fan Replacement, Keyboard: étape 4, image 3 de 3
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Fan Replacement: étape 5, image 1 de 2 Dell Latitude D610 Fan Replacement: étape 5, image 2 de 2
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Fan Replacement: étape 6, image 1 de 2 Dell Latitude D610 Fan Replacement: étape 6, image 2 de 2
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Fan Replacement: étape 7, image 1 de 3 Dell Latitude D610 Fan Replacement: étape 7, image 2 de 3 Dell Latitude D610 Fan Replacement: étape 7, image 3 de 3
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
  8. Dell Latitude D610 Fan Replacement, Fan: étape 8, image 1 de 2 Dell Latitude D610 Fan Replacement, Fan: étape 8, image 2 de 2
    • Remove the two 3.9mm Philips #1 screws from the case.
  9. Dell Latitude D610 Fan Replacement: étape 9, image 1 de 2 Dell Latitude D610 Fan Replacement: étape 9, image 2 de 2
    • Remove the sixteen 3.9mm Philips #1 screws from the back.
  10. Dell Latitude D610 Fan Replacement: étape 10, image 1 de 3 Dell Latitude D610 Fan Replacement: étape 10, image 2 de 3 Dell Latitude D610 Fan Replacement: étape 10, image 3 de 3
    • Turn the computer over. Using an opening tool seperate the top cover from the rest of the frame.
    • Do not open the computer too widely or quickly. Doing so will result in damage to the computer.
  11. Dell Latitude D610 Fan Replacement: étape 11, image 1 de 3 Dell Latitude D610 Fan Replacement: étape 11, image 2 de 3 Dell Latitude D610 Fan Replacement: étape 11, image 3 de 3
    • Remove the 3.9 mm Philips #1 screw.
    • Unplug the fan cable.
    • Lift fan out of compartment to remove the fan.
2 autres ont terminé cette réparation.
Jordan Barham
Membre depuis le 01/26/14
459 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-24, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 20
Total : 3,237
