Introduction
Replacing a defective modem is fairly simple and will help your computer in connecting to networks requiring a modem.
Pièces
Aucune pièce nécessaire.
Remove the 3.9 mm Phillips #1 screw from the battery compartment. Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
Ajouter un commentaire
Locate the laptop battery release button lock Push the battery release in the direction of the arrow, and pull upward. Push the battery release in the direction of the arrow, and pull upward.
  • Locate the laptop battery release button lock
  • Push the battery release in the direction of the arrow, and pull upward.
Remove the battery from its compartment.
  • Remove the battery from its compartment.
Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
  • Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
Lift and remove the lid. Lift and remove the lid.
  • Lift and remove the lid.
Remove the 3.9mm Philips #1 screw on top of the modem. Remove the 3.9mm Philips #1 screw on top of the modem.
  • Remove the 3.9mm Philips #1 screw on top of the modem.
Pull on the white tab to remove the modem Remove the cable going to the modem. Remove the cable going to the modem.
  • Pull on the white tab to remove the modem
  • Remove the cable going to the modem.
Jose Chavez
Membre depuis le 26/01/2014
113 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 6-24, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 membres
5 tutoriels rédigés
I have manufacturing mode problem can you help me??
Mod - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 1,219
