Introduction
Installing a new cd drive into the D620.
Pièces
Aucune pièce nécessaire.
Power down the laptop and remove the battery.
  • Power down the laptop and remove the battery.
  • Open the laptop cover all of the way.
Ajouter un commentaire
Locate the notch under the cover at the top of the keyboard Using the spudger as a lever, lift the plastic covering Carefully remove the rest of the covering from right to left
  • Locate the notch under the cover at the top of the keyboard
  • Using the spudger as a lever, lift the plastic covering
  • Carefully remove the rest of the covering from right to left
Unscrew the top portion of the keyboard using a #00 screwdriver
  • Unscrew the top portion of the keyboard using a #00 screwdriver
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
  • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
  • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
Once keyboard is out of the case, lay it face-down on the track pad Once keyboard is out of the case, lay it face-down on the track pad
  • Once keyboard is out of the case, lay it face-down on the track pad
Using a small spudger, pull back on the black bar to release the blue lever Using a small spudger, pull back on the black bar to release the blue lever
  • Using a small spudger, pull back on the black bar to release the blue lever
Pull up on the metal bar connected to the socket to detach the ribbon cable
  • Pull up on the metal bar connected to the socket to detach the ribbon cable
Press in the tab on the bottom right side of the CD drive The tab comes out on its own; there is no need to pull it out manually.
  • Press in the tab on the bottom right side of the CD drive
  • The tab comes out on its own; there is no need to pull it out manually.
Gently pull the tab to remove the disk tray.
  • Gently pull the tab to remove the disk tray.
So easy a caveman could do it
David Kehley - Réponse
9 autre(s) ont terminé cette réparation.
Ivan
Membre depuis le 15/04/2010
149 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 24-35, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 7,584
